Date/Time: Thu, 19 Nov 2026 12:57:31 +0000
Sierra Chart UI Flickering Issue
View Count: 695
[2024-09-05 03:24:43]
User366127 - Posts: 2
Hi
When using Sierra Chart software on my HP EliteBook x360 1030 G7 laptop (specs listed below), I experience UI flickering and overlapping of UI elements after several minutes of use. Minimizing and maximizing the window temporarily resolves the issue, but it reoccurs after a short time. This problem does not occur on my PC, so I suspect it may be related to my laptop’s resources.
Laptop Specifications:
Model: HP EliteBook x360 1030 G7 Notebook PC
CPU: Intel(R) Core(TM) i7-10610U @ 1.80GHz, 4 Cores, 8 Logical Processors
RAM: 32 GB
Graphics: Intel(R) UHD Graphics, 1 GB VRAM
I've attached some images for reference.
Kalhara
imageExpected.PNG / V - Attached On 2024-09-05 03:22:40 UTC - Size: 293.23 KB - 262 views
imageOverlap.PNG / V - Attached On 2024-09-05 03:22:51 UTC - Size: 294.64 KB - 287 views
[2024-09-05 14:14:45]
We are not seeing any particular difference in the images you sent. Please give us just a single chart and point out where the differences are. Follow the instructions at the following link to get us an image:
[2024-09-05 15:31:23]
If you look to the left to the Overlap.png you will see DOM overlapped over other charts. In the "Expected.PNG" you will not see the same DOM overlap.
[2024-09-05 16:00:12]
There is a DOM window behind those other windows, so it is visible since there is spacing between the charts. You would need to change the size of the windows to cover that so you do not see it. This is completely a setup/configuration on your side. It is nothing special about Sierra Chart, or anything weird occurring.
