Date/Time: Thu, 19 Nov 2026 12:57:18 +0000
Study: Midpoint of Bar/Candle
View Count: 644
[2024-09-04 19:44:04]
User688525 - Posts: 403
Hello Sierra Chart,
Is there an OHLC built-in study that can be used to mark the midpoint of each bar/candle?
Thank you
[2024-09-04 22:26:02]
There is not a study that does exactly this, but you can make the "Moving Average - Simple" study do this for you. On that study, set the following:
- Input Data: HL Avg
- Length: 1
Set the Draw Style for the subgraph as you want in order to view the midpoint as you want.
Refer to the following:
Chart Studies: Subgraphs Tab >> Draw Style
[2024-09-05 00:15:48]
Hi John,
Thank you. This solution works as required!
