Date/Time: Thu, 19 Nov 2026 12:57:20 +0000
trouble connecting to data feed
View Count: 466
| [2024-09-03 17:23:54] |
| User852686 - Posts: 2 |
I am not able to connect to data feed within Sierra charts. When i try to manually connect the data feed in the File drop-menu, it tells me my username or password is incorrect. I'm not sure which username or password I'm supposed to be using because when I try to enter the same sign-in info that I use to login to sierra chart platform in the data/trade service settings it doesn't work. My service package and cme data package are both paid up.
| [2024-09-04 19:40:41] |
| John - SC Support - Posts: 48583 |
It looks like you are trying to connect to CQG, so the Username/Password that it is referring to are your CQG Username/Password as entered in the "Global Settings >> Data/Trade Service Settings >> Main Settings". Ensure these items are correct on that page.
For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-04 19:40:55
