Date/Time: Thu, 19 Nov 2026 13:09:34 +0000
MOVAVGTYPE_NUMBER_OF_AVERAGES Question
View Count: 464
| [2024-08-30 18:29:41] |
| TriStar Trading - Posts: 201 |
I see this constant in the .h file but cannot find any documentation anywhere. What does it refer too? I was looking for an MA like the Running Moving Average in Trading View. Thanks!
| [2024-08-30 19:38:47] |
| John - SC Support - Posts: 48583 |
That constant defines the number of Moving Average options are available within that list of constants. It is not a Moving Average type itself. We have many Moving Averages available through studies, although not all of them can be called directly (that is where the list above comes into play). Refer to the studies starting with "Moving Average" at the following link: Technical Studies Reference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
