Date/Time: Thu, 19 Nov 2026 13:09:38 +0000
Is this a scaling problem?
View Count: 528
| [2024-08-29 18:13:04] |
| BigBagel - Posts: 69 |
What would i need to change to try and fit more in the the frame?
Private File |
| [2024-08-29 19:19:18] |
| John - SC Support - Posts: 48583 |
You need to change the Bar Spacing in order to see more bars within the display. Refer to the following: Working With Charts: Changing Bar Spacing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
