Date/Time: Thu, 19 Nov 2026 13:09:35 +0000
have real time on my other computer
View Count: 479
| [2024-08-29 15:02:00] |
| User285770 - Posts: 41 |
Hello, I want to have real time on my other computer that I use with Sierra, how to do it? Thank you, have a wonderful day |
| [2024-08-29 15:45:07] |
| John - SC Support - Posts: 48583 |
If you are not using the computers at the same time, then you do not need to do anything special. Just make sure Sierra Chart is only running on the one system at a time. If you want to get the data to two computers at the same time, then you need to pay for a second set of exchange fees. Refer to the following: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
