Date/Time: Thu, 19 Nov 2026 13:09:33 +0000
Stocks
View Count: 457
| [2024-08-29 14:51:05] |
| User841161 - Posts: 357 |
Do you have Airbnb Stock Quote- ABNB Symbol or Carvana Stock- CVNA Symbol. I looked under NASDAQ TotalView and can't find.
| [2024-08-29 15:43:15] |
| John - SC Support - Posts: 48583 |
Not all the symbols are listed on the "Find Symbol" page, as there simply are too many. You just need to type in the symbol in the "Selected Symbol" area on the Find Symbol window and then select the type of chart you want to open. Keep in mind that if you want the data from our "U.S. Equities Consolidated Tape" exchange, then you just type in the standard symbol, such as CVNA. If you want the data from our NASDAQ TotalView exchange, then you need to type in the symbol with the -NQTV suffix, such as CVNA-NQTV. For more information on the differences in these exchanges refer to the following: Denali Exchange Data Feed: US Equities Consolidated Tape Data Feed Notes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
