Date/Time: Thu, 19 Nov 2026 13:09:40 +0000
Increase price levels in trading DOM?
View Count: 1071
| [2024-08-29 00:23:14] |
| User212833 - Posts: 18 |
Hi, this seems like an easy issue but I've read through the boards and documentation and I still can't find the answer. When I open a Trading DOM, it seems to be limited to 40 price levels....when I expand the window down it just makes the levels larger. I would like more than 40 levels visible.....like I would like to drag down a long window to have maybe 100 levels available. I understand the bid/ask data won't be available for all the levels, but I would still like to have them visible. |
| [2024-08-29 13:29:49] |
| John - SC Support - Posts: 48583 |
The Trading DOM scale is set to "Constant Range". So when you expand the window, it is keeping the same range of data. You need to then adjust the scale to show more information. Refer to the following: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale If you are stating that you only are getting a total of 40 levels of Market Depth data, then refer to the following: File Menu: Not Receiving the Full Number of Market Depth Levels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
