Date/Time: Thu, 19 Nov 2026 13:09:26 +0000
Time zone / time shown
View Count: 675
[2024-08-28 16:18:24]
User826949 - Posts: 22
I am set to NY Time zone in Sierra but the Sierra clock is showing the time an hour later then what it should be. The computer is also set to NY but showing the correct time. I've had it set like this for years, didn't change anything. Since yesterday it's messed up. order fills not showing correctly either on the chart. Any suggestion why this could be?
[2024-08-28 16:21:12]
The "Clock - Real Time" has an Input that allows you to offset the time (Hour Offset). Make sure this is set to 0. Refer to the following:
Clock - RealTime: Inputs
For a particular chart where the order fills are not correct, what is the setting for "Chart >> Chart Settings >> Session Times >> Time Zone"?
And what is the setting for "Global Settings >> Time Zone"?
[2024-08-30 07:06:23]
Clock Hour Offset : 0
Session Times Time Zone : Global Time Zone
Global Settings > Time Zone : NY
The issue seems to have corrected itself by the 3rd day. I am watching it.
Thank you.
