Date/Time: Wed, 18 Nov 2026 09:39:37 +0000
delta dependent candlestick colors
View Count: 1955
| [2024-08-27 18:25:16] |
| pete3m - Posts: 15 |
Is it possible to change the entire candlestick shading based on delta in this tickchart format? https://www.sierrachart.com/image.php?Image=1724782844841.png Thank you. |
| [2024-08-27 20:03:49] |
| John - SC Support - Posts: 48568 |
Use the "Color Bar Based on Alert Condition" to do this. Refer to the following: Color Bar Based on Alert Condition You can get the delta from various locations, but the simplest is the Numbers Bars Calculated Values. Refer to the following: Numbers Bars: Displaying Numeric Information Below Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-08-27 21:05:00] |
Thank you, would this apply a gradient to the bars as well? - Meaning different colors depending on the range threshold of delta etc. Or do you need multiple Colo Bar Based studies for each color?
Date Time Of Last Edit: 2024-08-27 21:15:44
| [2024-08-28 12:32:51] |
The Color Bar Based on Alert Condition does not have an ability to apply a gradient. You would need multiple copies of the "Color Bar Based on Alert Condition" study to get the range of colors you want.
| [2024-08-28 13:00:16] |
Oof, OK that's what I was trying to accomplish. It would be great if Sierra would reformulate that Study to rebase on multiple outputs from the underlying study. Thank you for clarifying
| [2024-08-28 15:05:36] |
| Sierra_Chart Engineering - Posts: 25439 |
In this case you need to create your own custom study to do what you need. Refer to: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-08-30 21:24:42] |
I'm not sure what I'm doing wrong - I can't get the bars to change colors after reading the documentation. For Color Bar Based on Alert -based on Numbers Bars Calculated Value, chart region 1 (as the 1000 tick candles) -Value Format set to Inherited; Use Input Data (4); ID4.SG1 (15) -Alert condition "= ID4.SG1 >= 100" -"Evaluate on Bar Close" check or uncheck doesn't make a difference From the numbers bars it is clear there are values over 100, candles remain the same default colors. What am I missing? https://www.sierrachart.com/image.php?Image=1725052638511.png Date Time Of Last Edit: 2024-08-30 21:25:10
| [2024-08-31 19:31:29] |
Based On needs to be set to <Main Price Graph>. For the Color Bar Based on Alert Condition the "Based On" needs to be the item that is going to be colored.
