Date/Time: Wed, 01 May 2024 05:19:06 +0000
Using a second SC desktop under same license for the purpose of two data feeds
View Count: 937
[2014-08-31 11:57:07] |
ripsdips - Posts: 143 |
My question around using a second SC desktop under same license for the purpose of two data feeds is.....on Desktop 1 I have all my charts, setup with studies...WILL I be able to access those templates under the ANALYSIS tab on desktop 2 or is there another way to access those templates on the secondary desktop?
[2014-08-31 19:57:52] |
You need to copy the files to the other installation of Sierra Chart. This is explained in help topic 15: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
