Date/Time: Thu, 19 Nov 2026 13:27:32 +0000
How to reposition the symbol, countdown timer, and clock study
View Count: 594
| [2024-08-16 00:09:45] |
| mrchet - Posts: 25 |
For the life of me, I can't remember how I moved any of these studys so they appear at a different place (than default) in the chart window. In study settings, horizontal position from left vertical position from bottom, DO NOT change the position at all. Thanks |
| [2024-08-16 17:56:16] |
| Sierra_Chart Engineering - Posts: 25441 |
You have to move them like a chart drawing since they are text to drawings : Chart Drawing Tools: Move Drawing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-16 17:56:43
