Date/Time: Thu, 19 Nov 2026 13:27:22 +0000
Gaps between candles/candles missing
View Count: 834
[2024-08-14 22:42:33]
User378324 - Posts: 4
For existing chartbook I'm experiencing problems with data, specifically gaps between candles and missing parts on chart on multiple symbols, see attached.
imageCapture.PNG / V - Attached On 2024-08-14 22:42:08 UTC - Size: 79.56 KB - 198 views
[2024-08-15 13:22:23]
Based on the times we can see, it looks like your Session Times are not covering the full trading hours, which is why you have a gap. Refer to the following:
Chart Session Times
[2024-08-15 23:16:09]
It doesn't seem so, please check the attached there are still gaps even though each trading hour within the whole session is covered, this same issue happens on multiple symbols with same settings in random points on the charts.
imageCapture.PNG / V - Attached On 2024-08-15 23:14:55 UTC - Size: 39.12 KB - 264 views
[2024-08-16 17:52:03]
That does not look unusual to us in the case of crypto currencies. Especially in the case of Binance data which has a lot of issues. We cannot help further with this. But do try re-downloading the data:
