Date/Time: Sun, 05 May 2024 07:36:16 +0000
Multiple charts displayed
View Count: 1187
[2014-08-29 18:45:03] |
User89437 - Posts: 4 |
How exactly do I display more than 1 chart at a time in the window. Thank you. Barbara |
[2014-08-29 18:59:10] |
What you need to do is open charts through File >> Find Symbol and then you can arrange them with Window >> Tile Vertically/Horizontally. You can also manually move and resize the charts as needed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
