Date/Time: Wed, 19 Aug 2026 23:53:29 +0000
Download Failed Message
View Count: 1348
[2014-08-29 11:56:39]
infpz - Posts: 826
Please see image - customer is enabled for the markets that are failing. Any idea how to correct?
image12345.png / V - Attached On 2014-08-29 11:55:59 UTC - Size: 58.16 KB - 441 views
[2014-08-29 16:15:20]
There was a problem in version 1180 causing this. It has now been resolved. Update Sierra Chart by selecting Help >> Download Prerelease.
[2014-08-29 16:21:23]
infpz - Posts: 826
can I use "old spreadsheets"? because I just did that and still get 1180 and the same error.
[2014-08-29 16:27:11]
Yes you can use Old Spreadsheets.
We are checking the different downloads now to make sure that the problem is fixed.
[2014-08-29 17:14:34]
Update Sierra Chart again and you will get 1181. You should not see the problem any longer.
