Date/Time: Thu, 20 Aug 2026 00:37:40 +0000
Span A and B....how can I make the candle be seen as it passes through the filled span?
View Count: 1225
| [2014-08-28 17:14:57] |
| ripsdips - Posts: 143 |
how can I make the candle be seen as it passes through the filled span? http://www.sierrachart.com/image.php?l=1409245947226.png |
| [2014-08-28 17:59:12] |
| vegasfoster - Posts: 444 |
F6>>Settings>>Subgraphs>>Draw Style and change Span A to Fill Rect Top and Span B to Fill Rect Bottom.
| [2014-08-29 12:33:26] |
| stevel - Posts: 19 |
You can also tick the box 'Draw Study Underneath Main Price Graph' on the Settings and Inputs tab for each study that needs it.
| [2014-08-29 17:13:22] |
You need to set the study to be drawn underneath the main price graph. Here is the documentation for that: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DisplayStudyUnderMPG Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
