Date/Time: Thu, 19 Nov 2026 12:59:43 +0000
In footprint, im Looking for put/spot coloring for invert imbalance
View Count: 661
| [2024-07-27 13:47:46] |
| Misanirina - Posts: 49 |
(See the picture in attach) Hi, I'm looking for spot or put color for invert imbalance. How to do that ? If you see picture in the red circle, Bid line is bigger than Ask line but it coloring as green imbalance. How to do that ? Thanks |
| [2024-07-29 14:46:21] |
| John - SC Support - Posts: 48583 |
We are not understanding what you are wanting to do. Please give us more information on what you are wanting. Also, the account you have posted from is Expired. We do not give support for expired accounts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-09-01 14:47:37] |
See the picture in attach. In this situation, How to have the red color inside the red renko bar on this level when the ask is bigger than the bid ? Thanks |
| [2024-09-04 14:36:32] |
To color the text in a Numbers Bars, you need to select the particular Text Coloring option. Refer to the following: Numbers Bars: Numbers Bars Text Coloring Methods And then you can set the colors as you want. Note that you can have separate text colors from the bars. Refer to the following: Numbers Bars: Use Separate Colors for Text Coloring Method For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
