Date/Time: Tue, 28 May 2024 17:13:30 +0000
time by price level
View Count: 988
[2014-08-27 18:23:17] |
jivetrader - Posts: 395 |
hello, is there a way to show a profile (similar to Volume by Price) of Time by Price? i am not looking for Market Profile letters, just a basic histogram of how much time price has spent at each price level. thanks
[2014-08-28 15:44:45] |
Yes. This is the TPO Profile Chart: http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html You can set it to use blocks rather than letters. This is all that Sierra Chart has that sounds closest to what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
