Date/Time: Sun, 19 May 2024 21:13:29 +0000
Study Drawings
View Count: 876
[2014-08-27 00:45:56] |
User21113 - Posts: 62 |
The OHLC study "Number of Days to Calculate" is set to 2. The High is drawn correctly on each day, but between the days there is a green vertical line which connects each high. Can this connecting line be removed? See the attachment. |
Study Lines.JPG / V - Attached On 2014-08-27 00:40:49 UTC - Size: 54.94 KB - 373 views |
[2014-08-27 01:59:10] |
To remove this it is necessary to set the Subgraph Draw Style for each of the Subgraphs to Dash or some other non-connecting Draw Style.
[2014-08-27 05:33:01] |
ejtrader - Posts: 688 |
Draw Style -> left/Right Hash would solve this issue.
[2014-08-27 12:44:40] |
Thanks, that works.
