Date/Time: Sun, 19 May 2024 12:53:28 +0000
Making a histogram that does not start at 0
View Count: 1188
[2014-08-26 19:11:06] |
User12676 - Posts: 70 |
Hi, In ascil, is it possible to make a histogram that does not start at 0? To have a bars start and end in different places? Pls check attachment for example. Thanks. |
snapshot-0.png / V - Attached On 2014-08-26 19:10:49 UTC - Size: 1.86 KB - 349 views |
[2014-08-27 05:23:09] |
Yes. To do this you need to use the Bar Top and Bar Bottom Subgraph Draw Style pair.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-27 07:20:14
[2014-08-27 08:56:57] |
Thank you, i got it now
