Date/Time: Sun, 19 May 2024 14:46:26 +0000
Erase all lines prompt
View Count: 906
[2014-08-26 13:55:30] |
GCAdmin - Posts: 35 |
Is there a way to disable the new prompt you get when you select Tools --> Erase All Lines? Thanks, |
[2014-08-26 15:34:19] |
In the latest Sierra Chart prerelease, there is an option to disable this in Global Settings >> Tool Settings. Update Sierra Chart by selecting Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
