Date/Time: Sat, 18 May 2024 06:22:36 +0000
Is OEC prod connection down?
View Count: 1191
[2014-08-25 21:39:55] |
NumbersBars - Posts: 141 |
I am unable to connect to OEC live feed. Here is the log. Just to confirm if it is OEC server problem. OEC FIX/FAST | 9400. | 2014-08-25 21:37:20 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-25 21:37:20 OEC FIX Trading socket (772) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time or established connection failed because connected host has failed to respond. | 2014-08-25 21:37:41 OEC FIX Trading socket (772) | Shutdown and closed. | 2014-08-25 21:37:41 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-08-25 21:37:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-25 21:37:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-25 21:37:41 Disconnected from Open E Cry. | 2014-08-25 21:37:42 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-25 21:37:42 |
[2014-08-25 22:15:32] |
[update] It is up now.
