Date/Time: Tue, 15 Jul 2025 19:21:35 +0000
Color bar based on alert condition
View Count: 616
[2024-07-03 00:27:43]
Lilydo - Posts: 15
I used study Color bar based on alert condition to set the color of the candle. Would you pls help to get the line under the candle like attached files. My candles don't have the line under.
Lily
imageCandle without line under.jpg / V - Attached On 2024-07-03 00:26:57 UTC - Size: 9.5 KB - 121 views
[2024-07-03 13:44:02]
John - SC Support - Posts: 40908
The image is too small for us to be able to make anything out from it. Please get us an image by following these instructions:
[2024-07-10 03:26:15]
Lilydo - Posts: 15
I have only picture because I cannot set up like this.
Pls open the attached file.
How can set up the line under candle with my conditional alert?
Thank you,
Lily
imageLine under candle.jpg / V - Attached On 2024-07-10 03:25:05 UTC - Size: 85.84 KB - 85 views
[2024-07-10 13:16:03]
It looks like that is an extension line. Refer to the following and the Input below it:
Color Bar Based on Alert Condition: Draw Extension Lines at Color Bar Value
[2024-07-10 14:33:31]
Lilydo - Posts: 15
Thank you for quick response. I tried but it is not working.
Pls give me advise
imageLine under candle 1.jpg / V - Attached On 2024-07-10 14:33:12 UTC - Size: 177.55 KB - 95 views
imageLine under candle 2.jpg / V - Attached On 2024-07-10 14:33:22 UTC - Size: 252.65 KB - 96 views
[2024-07-10 15:28:48]
Your "Output when Condition True" is set to "1.0". So the Extension Lines are being drawn at a value of 1.0. You need to change that to be where you want to see the extension lines. Refer to the following:
Color Bar Based on Alert Condition: Output When Condition Is True
[2024-07-10 15:45:38]
Lilydo - Posts: 15
Hi John,
I did it. I appreciate your support.
How can I set up Large Volume trade Indicator follow tick?
How can I set 1 line when bubble over 100? ( attached file)
Thank you
imageLarge Volume Trade Indicator.png / V - Attached On 2024-07-10 15:45:06 UTC - Size: 483.68 KB - 84 views
[2024-07-10 16:56:47]
The documentation for the Large Volume Trade Indicator is here:
There is not a way to get an extension line with the "Large Volume Trade Indicator", as this is not built into the study, and the information for the location of the markers is not exposed through the study.
[2024-07-11 01:33:55]
Lilydo - Posts: 15
Is there any way to set the bubble like Bookmap on Sierra Chart?
And according to you, how can I set the line when the bubble over 100?
Thank you,
Lily
[2024-07-11 01:36:28]
Lilydo - Posts: 15
Is the large volume trade indicator only way to show time and sale window on the chart ?
[2024-07-11 14:06:41]
Use the "Large Volume Trade Indicator" to get the bubbles. Refer to the following:
And as we stated, there is not a way to get extension lines with the Large Volume Trade Indicator
You can open a separate window for the Time and Sales. Refer to the following:
Time and Sales Window
[2024-07-17 17:08:02]
Lilydo - Posts: 15
Hi John,
Thank for your information. I will try another way.
Do you know how to set the line chart always stands in front of the vertical number line. My chart is like the attached file.
Thank you,
Lily
imageHeatmap.png / V - Attached On 2024-07-17 17:07:35 UTC - Size: 79.92 KB - 77 views
[2024-07-17 17:25:21]
We are not understanding.
If you are referring to the Market Depth Historical Graph stopping and not showing on some of the more current bars, then this is due to not having the Market Depth data for those bars. Refer to the following (not Step #8 in particular):
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
[2024-07-17 23:58:24]
Lilydo - Posts: 15
I'm sorry for not explaining clearly. Would you pls see these attached files and tell me how to set up the chart like this. The line on close chart is always in front of the white number vertical.
Thank you,
Lily
imageHeatmap.png / V - Attached On 2024-07-17 23:56:33 UTC - Size: 95.94 KB - 96 views
imageHeatmap1.png / V - Attached On 2024-07-17 23:56:41 UTC - Size: 157.68 KB - 88 views
[2024-07-18 13:49:14]
User14953 - Posts: 256
How to configure the price scale tic marks like example lilydo "line under candle1.jpg"
Date Time Of Last Edit: 2024-07-18 13:49:50
imageldp.jpg / V - Attached On 2024-07-18 13:48:59 UTC - Size: 27.79 KB - 91 views
[2024-07-18 14:11:16]
Lilydo - Posts: 15
Right click on the line--> Chart drawing properties-->setting --> choose YES on Show End Point Price
[2024-07-18 16:12:45]
The Market Depth Historical Graph has an Input for "Show Quantity Numbers" in which one of the options is "Only After Last Bar". When choosing this option, there is another Input for "Percentage of Fill Space To Display Market Depth Quantity Rectangles In". You want to set this to a value that will put the numbers where you want them ahead of the bars. Refer to the information at the following link:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph
[2024-07-18 19:24:06]
Lilydo - Posts: 15
It is not working. The chart is still like this. The heatmap not following the price chart. I sent the study of heatmap setting. Pls give me your advises.
imageHeatmap2.png / V - Attached On 2024-07-18 19:22:57 UTC - Size: 82.54 KB - 86 views
imageHeatmap3.png / V - Attached On 2024-07-18 19:23:06 UTC - Size: 77.02 KB - 78 views
[2024-07-18 20:15:25]
We do not know. Everything looks good from what we can see.
Please get us that chart by following these instructions:
[2024-07-18 20:45:10]
Lilydo - Posts: 15
2024-07-15 07:01:02.646 | TradeActivity files query time: 0.036193 seconds. Entries: 0. Current queries: 2
2024-07-15 07:01:02.869 | TradeActivity files query time: 0.223463 seconds. Entries: 0. Current queries: 2
2024-07-15 07:01:09.937 | Teton CME Order Routing | Requesting trade accounts from server.
2024-07-15 07:01:10.024 | Teton CME Order Routing | Performing query for most recent order fills Date-Time for Trade Account: 48781.
2024-07-15 07:01:10.024 | Teton CME Order Routing | Performing query for most recent account balances Date-Time for Trade Account: 48781.
2024-07-15 07:01:10.024 | Teton CME Order Routing | Received 1 accounts from service.
2024-07-15 07:01:10.066 | TradeActivity files query time: 0.127889 seconds. Entries: 0. Current queries: 3
2024-07-15 07:01:10.167 | TradeActivity files query time: 0.100574 seconds. Entries: 0. Current queries: 2
2024-07-15 07:01:10.167 | Teton CME Order Routing | Requesting historical order fills for account 48781. Start Date-Time UTC: 2024-03-13 07:01:10
2024-07-15 07:01:10.167 | TradeActivity files query time: 0.000407 seconds. Entries: 0. Current queries: 1
2024-07-15 07:01:10.167 | Teton CME Order Routing | Requesting historical account balances for account 48781. Start date-time UTC: 2024-07-13 16:04:19
2024-07-15 07:01:10.188 | Teton CME Order Routing | Requesting Trade Positions data.
2024-07-15 07:01:10.301 | Teton CME Order Routing | Received 0 order fills for account: 48781. Inserting the ones that do not exist.
2024-07-15 07:01:10.375 | Teton CME Order Routing | Received 0 historical account balance updates for account: 48781.
2024-07-15 07:02:13.748 | TradeActivity files query time: 0.001581 seconds. Entries: 0. Current queries: 1
2024-07-15 07:04:24.631 | TradeActivity files query time: 0.024211 seconds. Entries: 0. Current queries: 1
2024-07-15 07:04:24.791 | TradeActivity files query time: 0.000450 seconds. Entries: 0. Current queries: 2
2024-07-15 07:04:25.268 | TradeActivity files query time: 0.000756 seconds. Entries: 0. Current queries: 3
2024-07-15 07:04:42.613 | TradeActivity files query time: 0.000721 seconds. Entries: 0. Current queries: 1
2024-07-15 07:04:46.069 | Denali Data Feed | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-15 07:04:46.069 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-15 07:04:47.604 | Denali Data Feed (Market Orders Data) | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-15 07:04:47.604 | Denali Data Feed (Market Orders Data) | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-15 07:05:41.442 | TradeActivity files query time: 0.000765 seconds. Entries: 0. Current queries: 1
2024-07-15 07:06:16.040 | TradeActivity files query time: 0.000679 seconds. Entries: 0. Current queries: 1
2024-07-15 19:43:35.681 | Denali Data Feed (Market Orders Data) | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-15 19:43:35.681 | Denali Data Feed (Market Orders Data) | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-16 08:41:15.509 | Denali Data Feed | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-16 08:41:15.509 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-16 08:41:16.253 | Denali Data Feed (Market Orders Data) | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-16 08:41:16.253 | Denali Data Feed (Market Orders Data) | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-16 20:45:26.427 | TradeActivity files query time: 0.583800 seconds. Entries: 0. Current queries: 1
2024-07-16 20:45:30.226 | TradeActivity files query time: 0.000705 seconds. Entries: 0. Current queries: 2
2024-07-16 20:46:15.454 | TradeActivity files query time: 0.000695 seconds. Entries: 0. Current queries: 1
2024-07-16 20:46:15.465 | TradeActivity files query time: 0.000535 seconds. Entries: 0. Current queries: 2
2024-07-16 20:46:37.298 | TradeActivity files query time: 0.000551 seconds. Entries: 0. Current queries: 3
2024-07-16 20:46:56.338 | TradeActivity files query time: 0.001306 seconds. Entries: 0. Current queries: 1
2024-07-16 20:46:58.088 | TradeActivity files query time: 0.000690 seconds. Entries: 0. Current queries: 2
2024-07-16 20:47:06.164 | TradeActivity files query time: 0.001126 seconds. Entries: 0. Current queries: 3
2024-07-16 20:47:13.972 | TradeActivity files query time: 0.000950 seconds. Entries: 0. Current queries: 4
2024-07-16 20:47:28.929 | TradeActivity files query time: 0.000642 seconds. Entries: 0. Current queries: 1
2024-07-16 20:48:07.515 | TradeActivity files query time: 0.024265 seconds. Entries: 0. Current queries: 1
2024-07-16 20:48:08.844 | TradeActivity files query time: 0.001480 seconds. Entries: 0. Current queries: 1
2024-07-16 20:48:09.535 | TradeActivity files query time: 0.000589 seconds. Entries: 0. Current queries: 1
2024-07-16 20:48:14.572 | TradeActivity files query time: 0.001021 seconds. Entries: 0. Current queries: 1
2024-07-16 20:48:16.214 | TradeActivity files query time: 0.000510 seconds. Entries: 0. Current queries: 2
2024-07-16 20:48:22.358 | TradeActivity files query time: 0.001267 seconds. Entries: 0. Current queries: 1
2024-07-17 01:08:29.876 | Denali Data Feed (Market Orders Data) | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-17 01:08:29.876 | Denali Data Feed (Market Orders Data) | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-17 01:08:52.097 | Denali Data Feed | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-17 01:08:52.097 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-17 01:08:53.177 | Denali Data Feed (Market Orders Data) | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-17 01:08:53.177 | Denali Data Feed (Market Orders Data) | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-17 01:20:08.120 | Denali Data Feed | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-17 01:20:08.120 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-17 01:20:09.274 | Denali Data Feed (Market Orders Data) | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-17 01:20:09.274 | Denali Data Feed (Market Orders Data) | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-17 02:30:37.459 | Denali Data Feed | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-17 02:30:37.459 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-17 02:30:38.193 | Denali Data Feed (Market Orders Data) | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-17 02:30:38.193 | Denali Data Feed (Market Orders Data) | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-17 16:25:37.004 | TradeActivity files query time: 0.219666 seconds. Entries: 0. Current queries: 1
2024-07-17 16:28:34.468 | TradeActivity files query time: 0.001727 seconds. Entries: 0. Current queries: 1
2024-07-17 16:29:26.452 | TradeActivity files query time: 0.005836 seconds. Entries: 0. Current queries: 1
2024-07-17 16:30:25.286 | TradeActivity files query time: 0.002542 seconds. Entries: 0. Current queries: 1
2024-07-17 16:30:28.284 | TradeActivity files query time: 0.001246 seconds. Entries: 0. Current queries: 1
2024-07-17 16:33:23.865 | TradeActivity files query time: 0.002793 seconds. Entries: 0. Current queries: 1
2024-07-17 16:33:27.386 | TradeActivity files query time: 0.001065 seconds. Entries: 0. Current queries: 1
2024-07-17 16:37:28.936 | TradeActivity files query time: 0.001191 seconds. Entries: 0. Current queries: 1
2024-07-17 16:37:32.035 | TradeActivity files query time: 0.000994 seconds. Entries: 0. Current queries: 1
2024-07-17 21:06:12.347 | Denali Data Feed | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-17 21:06:12.347 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-17 21:06:14.274 | Denali Data Feed (Market Orders Data) | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 1
2024-07-17 21:06:14.274 | Denali Data Feed (Market Orders Data) | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
2024-07-18 06:34:48.625 | TradeActivity files query time: 0.138927 seconds. Entries: 0. Current queries: 1
2024-07-18 06:34:52.535 | TradeActivity files query time: 0.001474 seconds. Entries: 0. Current queries: 1
2024-07-18 06:38:02.930 | TradeActivity files query time: 0.001764 seconds. Entries: 0. Current queries: 1
2024-07-18 06:38:07.835 | TradeActivity files query time: 0.001387 seconds. Entries: 0. Current queries: 1
2024-07-18 08:03:10.021 | TradeActivity files query time: 0.004753 seconds. Entries: 0. Current queries: 1
2024-07-18 08:03:24.757 | TradeActivity files query time: 0.000854 seconds. Entries: 0. Current queries: 1
2024-07-18 08:03:31.453 | TradeActivity files query time: 0.001359 seconds. Entries: 0. Current queries: 1
2024-07-18 08:03:35.923 | TradeActivity files query time: 0.000899 seconds. Entries: 0. Current queries: 1
2024-07-18 08:04:43.942 | TradeActivity files query time: 0.000930 seconds. Entries: 0. Current queries: 1
2024-07-18 08:04:48.703 | TradeActivity files query time: 0.001212 seconds. Entries: 0. Current queries: 1
2024-07-18 08:04:53.551 | TradeActivity files query time: 0.001479 seconds. Entries: 0. Current queries: 1
2024-07-18 08:04:58.386 | TradeActivity files query time: 0.001605 seconds. Entries: 0. Current queries: 1
2024-07-18 08:05:03.126 | TradeActivity files query time: 0.000892 seconds. Entries: 0. Current queries: 1
2024-07-18 08:38:59.643 | TradeActivity files query time: 0.003614 seconds. Entries: 0. Current queries: 1
2024-07-18 08:41:53.885 | TradeActivity files query time: 0.002851 seconds. Entries: 0. Current queries: 1
2024-07-18 08:41:56.254 | TradeActivity files query time: 0.001205 seconds. Entries: 0. Current queries: 1
2024-07-18 08:41:58.821 | TradeActivity files query time: 0.002080 seconds. Entries: 0. Current queries: 1
2024-07-18 08:42:46.778 | TradeActivity files query time: 0.000985 seconds. Entries: 0. Current queries: 1
2024-07-18 08:42:51.490 | TradeActivity files query time: 0.002042 seconds. Entries: 0. Current queries: 1
2024-07-18 08:42:56.435 | TradeActivity files query time: 0.001198 seconds. Entries: 0. Current queries: 1
2024-07-18 17:29:26.621 | TradeActivity files query time: 0.160436 seconds. Entries: 0. Current queries: 1
2024-07-18 17:29:46.519 | TradeActivity files query time: 0.006905 seconds. Entries: 0. Current queries: 1
2024-07-18 17:30:05.918 | TradeActivity files query time: 0.003698 seconds. Entries: 0. Current queries: 1
2024-07-18 19:00:06.180 | TradeActivity files query time: 0.002148 seconds. Entries: 0. Current queries: 1
2024-07-18 20:29:02.013 | TradeActivity files query time: 0.030173 seconds. Entries: 0. Current queries: 1
2024-07-18 20:29:08.480 | TradeActivity files query time: 0.002388 seconds. Entries: 0. Current queries: 1
attachmentChartbook1.Cht - Attached On 2024-07-18 20:44:44 UTC - Size: 9.83 KB - 342 views
[2024-07-18 21:48:38]
We can not find a reason why you are seeing the data like this. The attached image shows what we see. We did change the "Lowest Quantity for Coloring" and added a Bid/Ask Market Depth column to view that data relative to the Market Depth Historical Graph. But the data was showing in the correct location even without these changes, there just was not much to see due to some large Market Depth value such that even a 20% of maximum depth for the minimum was removing most of the data.
Please do the following and then get us an image of your chart with this change:
- Set the "Lowest Quantity for Coloring" to "0".
imageGCQ24[M] 3 Sec #2 2024-07-19 04_44_46.966.png / V - Attached On 2024-07-18 21:47:06 UTC - Size: 92.81 KB - 73 views
