Date/Time: Sun, 19 May 2024 14:46:38 +0000
TPO lines don't match tp M Profile 30 minute.
View Count: 1116
[2014-08-22 20:06:03] |
User64662 - Posts: 15 |
How can I get M Profile 30 minute VAL POC VAH match up on 30 minute candles chart. Can someone show me the settings. I have read and tried so many settings no luck so far. The only way for me is draw them in and move the VAH VAL POC on candle chart. Thanks, CMan |
[2014-08-22 21:45:19] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#IncorrectValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-27 18:15:56] |
Bedhog - Posts: 168 |
I would be pleased with 'TPO Profile Chart' in its own minimized window if I could only overlay and add alerts to it's VAH and VAL on a smaller timeframe chart. What I really want is to be able to reference yesterday's (2 periods back) TPO VAH and VAL with a study overlay. I am manually drawing them in which is fine, but I cannot create a custom alert that takes into account other studies at the same time. Date Time Of Last Edit: 2014-08-27 18:16:33
[2014-08-27 19:02:30] |
I down loaded 1179 PreRelease and did horizontal lines of POC VAH VAL and NPOC with sound alerts and blinking lines on 15 min candle chart. First day testing on four computers. So far okay! I did try overlay's for TPO all different set ups just trying to get lines over candle chart no luck. Date Time Of Last Edit: 2014-08-27 19:04:50
[2014-08-27 23:28:00] |
I did try overlay's for TPO all different set ups just trying to get lines over candle chart no luck. For the TPO Value Area lines on a standard chart, use the TPO Value Area Lines study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-27 23:28:45
