Date/Time: Thu, 19 Nov 2026 14:41:54 +0000
How to stop 'Trade Window for Chart' openning on start
View Count: 594
[2024-06-11 17:32:28]
Tony - Posts: 733
It only happened in recent versions, the "Trade Window for Chart" opens automatically on start, even I close it and Save All, it will still open on next start.
Wonder if there is a setting to stop that? I couldn't find anywhere.
Thanks so much!
[2024-06-11 23:00:26]
John - SC Support - Posts: 48584
If the Trade Window is open when you save the chartbook, then it will open when the chartbook is opened. The opposite is also true, if you do not have a Trade Window open when you save a chartbook, then it will not open when you open a chartbook.
So there is something else going on in your situation. Make sure you hard drive is not full and therefore you are not actually saving a new version of the chartbook.
