Date/Time: Sun, 19 May 2024 09:17:09 +0000
Kiwi trailing stop
View Count: 2711
[2014-08-22 06:35:28] |
User17477 - Posts: 65 |
Hi Support, Can the Kiwi trailing stop be used to automatically trail my stop after I place a trade in Sierra chart? thanks |
[2014-08-22 11:28:37] |
PTG - Posts: 57 |
I am not from support but I have been using the Kiwi trailing stop to automatically trail my stop. Use the Trade Management by Study study to do that. Desciption is here: http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#StudyControlledTargetsStops |
[2014-08-22 17:34:56] |
You can try this and see how it works. We recommend first testing this in Trade Simulation Mode. You will need to use the Trade Management by Study study. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#StudyControlledTargetsStops Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-09 08:16:10] |
ILIM KIRGIZ - Posts: 187 |
I need Kiwi to draw values according to bar open ie, previous bar's close. How can I achieve this? Thanks. |
