Date/Time: Sat, 18 May 2024 06:48:52 +0000
Problem with Trading Chart DOM
View Count: 961
[2014-08-22 06:11:39] |
User35292 - Posts: 2 |
I have a problem with Trading Chart DOM. When I turn it on the feature in the graph appears to me, but I do not see any data on the volume of the securities of each. So ASK / BID are empty. Can you help with this problem. Thank you.
[2014-08-22 06:47:29] |
We need to see an image of this. Follow the instructions here to provide an image: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-22 16:39:11] |
http://www.sierrachart.com/image.php?l=1408725531643.png |
[2014-08-22 17:34:05] |
You need to add columns to the chart DOM which include Bid Size and Ask Size . Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOMPositionPLColumn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
