Date/Time: Sun, 19 May 2024 08:29:33 +0000
CTS T4 Trading Platform Service failed downloads
View Count: 1008
[2014-08-20 19:50:06] |
User57562 - Posts: 98 |
Upgraded SC demo to one month paid. FX thru CADILS worked on your feed. Followed http://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions and log says "No contract months found for symbol..." for either new or prior symbols. |
NoData=8-20-2014 1.28.41 PM.jpg / V - Attached On 2014-08-20 19:48:53 UTC - Size: 972.08 KB - 444 views |
[2014-08-20 20:05:01] |
None of the symbols you shown that image are valid CTS T4 symbols. They will not work when using CTS. You can find the CTS symbols through File >> Find Symbol.
[2014-08-20 20:15:45] |
Oops. Can you give simple explanation for why brokers and feeds differ so much on syms? And is there an easy way to export syms from FS to text or *.symbolList file? Now I screen capture, OCR, edit, and it is TEDIOUS. But the resulting list lets me scan thru charts quickly. Date Time Of Last Edit: 2014-08-20 20:21:02
[2014-08-20 20:23:31] |
No, we cannot provide an explanation. What would we say? The symbols in the Find Symbol window exist in GlobalSymbolSettings.XML file in the Sierra Chart folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-20 20:54:14] |
Unfortunately, that .xml only shows the group seed from which the full symbols are constructed. Any other suggestions? This OCR method is rough.
[2014-08-20 21:13:56] |
There really is not a way to export symbols from the Find Symbol window.
