Date/Time: Tue, 28 May 2024 04:32:03 +0000
Is closed chartbook active ?
View Count: 875
[2014-08-20 18:55:50] |
User021827 - Posts: 174 |
If I have an auto strategy on a chart enabled, and I close the chartbook, is that chart still active ? Will trades be placed from that chart in a closed chartbook ? regards |
[2014-08-20 20:08:21] |
No, it will not be active.
[2014-08-20 20:16:28] |
User120827 - Posts: 77 |
thanks I could not find anything in the documentation. Wanted to be sure. thanks regards shane |
