Date/Time: Sun, 19 May 2024 12:15:06 +0000
Lost Intraday Data between 10 - 11AM EST..Was that on my end or Sierra Issue?
View Count: 856
[2014-08-20 15:09:30] |
The Stealthy Trader - Posts: 162 |
Had to restart and all's well.. Just curious as now I have gaps in my charts.. Thanks, J. |
[2014-08-20 16:15:01] |
You are using TD Ameritrade, so this was a TD Ameritrade issue or some Internet connection issue. Definitely not with Sierra Chart. If you are missing data in Intraday charts, refer to help topic 7 here: https://www.sierrachart.com/index.php?l=helpdetails7.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-20 18:27:50] |
Thank you..
