Date/Time: Sun, 19 May 2024 07:45:27 +0000
Excel Spreadsheet
View Count: 813
[2014-08-20 01:11:20] |
George - Posts: 60 |
Is there a way to update an Excel text file (the text file has its own Symbol and plots like any other Symbol) that is located in the SC/Data Folder using an Excel macro from an Excel Workbook ? To explain, I have created my own indicators in an Excel Workbook, I update data manually, then Copy and Paste the data into an Excel text file that is located in the SC/Data Folder. Any advice would be greatly appreciated.
[2014-08-20 03:54:15] |
We can only recommend using the Spreadsheet study: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html Maybe that will meet your requirements. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
