Date/Time: Sun, 19 May 2024 08:35:59 +0000
Stock Symbols
View Count: 1280
[2014-08-19 22:04:33] |
User54158 - Posts: 1 |
I have an SC account for futures data and trading, what do I need to do to in order to receive stock symbols. Thank You |
[2014-08-20 00:30:29] |
dennismed - Posts: 62 |
http://screencast.com/t/NiQ7wSIlo please see the attached screenshot I have paid for the equities data feed but have no stock listed in the FS window Thank You |
[2014-08-20 00:51:39] |
In response to post #1: Follow the setup instructions here to use the Sierra Chart Real-time and Historical Exchange Data Feed:
http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php You will need to activate the US Equities exchange for 10.5USD a month assuming you want US stock data. We also assume you want real-time data? Within the second copy of Sierra Chart you will need to set the Service to "SC Exchange Data". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-20 00:52:44] |
In response to #2, did you want just historical data for stocks? Or did you need real-time data. In either case, you just manually type the stock symbol into the Selected Symbol box of the Find Symbol window and press one of the buttons below to open a chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-20 00:53:10
[2014-08-20 01:05:57] |
I want real-time data
[2014-08-20 01:09:10] |
http://screencast.com/t/d4i9lgGnRh attached is the latest screenshot I have opened 3 charts and still no data Thank You |
[2014-08-20 02:38:05] |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#logPost a copy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
