Date/Time: Sun, 19 May 2024 04:37:02 +0000
TDA not connecting
View Count: 892
[2014-08-19 14:07:40] |
M5amhan - Posts: 468 |
Hi, It is not connecting to TDA this morning TD Ameritrade | Connecting. | 2014-08-19 09:05:55 TD Ameritrade | Logging in. (Step 1 of 3) | 2014-08-19 09:05:55 TD Ameritrade | Authorized for streamer data. | 2014-08-19 09:05:56 TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2014-08-19 09:05:56 TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2014-08-19 09:05:57 TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2014-08-19 09:05:58 TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 12 | 2014-08-19 09:05:58 Connection timed out. Will disconnect and retry. | 2014-08-19 09:10:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-19 09:10:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-19 09:10:10 Disconnected from TD Ameritrade. | 2014-08-19 09:10:11 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-19 09:10:11 Date Time Of Last Edit: 2014-08-19 14:11:37
[2014-08-19 15:11:58] |
We can connect to TD Ameritrade at this time. Are you still having a problem?
[2014-08-19 15:14:49] |
no it connected shortly after i posted this. thanks
