Date/Time: Tue, 15 Jul 2025 16:59:05 +0000
slow down DOM
View Count: 376
[2024-05-22 17:07:57] |
sabbers - Posts: 27 |
Hi all, On the NQ the DOM moves very fast. Is there a setting to slow down the DOM a little bit? Regards, Sabbers |
[2024-05-22 17:14:11] |
John - SC Support - Posts: 40900 |
You would need to change the "Chart Update Interval" for that chart and make the value larger. Refer to the following: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Keep in mind, this will affect your entire chart and how often it updates. If this is a Trading DOM, then this does not matter, but if it is a standard Chart, then this will change how often the bars are drawn as well. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
