Date/Time: Sat, 05 Jul 2025 18:32:35 +0000
tick count
View Count: 431
[2024-05-22 16:55:59] |
SafSaf - Posts: 127 |
hi, i use the count down timer on my minute charts. is there a count down timer for the tick charts too please?
[2024-05-22 17:11:31] |
John - SC Support - Posts: 40745 |
It's the same study. If you apply it to a chart setup for "Number of Trades", then it will show you the number of trades remaining. If you apply it to a "Range" chart, then it will give you the remaining range. Refer to the following: Countdown Timer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
