Date/Time: Sun, 19 May 2024 04:56:22 +0000
1174: Lines horizontal appaering/dissapearing
View Count: 909
[2014-08-19 12:31:10] |
YSS - Posts: 107 |
I have around 6 stocks on a watch list, I draw horizontal lines i click on those 6 stocks and lines are appearing wrongly and disappearing where they were before. ? I have made a movie with my iphone, if you like I can email it to you. Date Time Of Last Edit: 2014-08-19 12:31:37
[2014-08-19 15:10:01] |
Make sure you have Chart >> Chart Settings >> Advanced Settings 2 >>Show Chart Drawings for Different Symbols unchecked
[2014-08-19 18:19:17] |
User36173 - Posts: 12 |
Thanks, that fixed it? this was a clean sierracharts install, I suggest you disable that by default? Thanks
[2014-08-19 23:29:20] |
We find there are fewer support questions with keeping it enabled.
