Date/Time: Sun, 19 May 2024 05:43:12 +0000
Tick data and slow loading times
View Count: 1096
[2014-08-18 21:00:41] |
corbeste - Posts: 74 |
Hi, I currently have my intraday data storage set to 1-tick. I require this for the very recent history (say a week or 2) but after that it becomes irrelevant. Is it possible to switch SC to use 1-second resolution after a certain cut-off? I am only downloading 20 days of tick data but I notice that the loading of ES in particular (due to high volume) becomes slower and slower as time goes on, which implies the actual tick history goes back much further. Thanks, Steve |
[2014-08-18 21:05:44] |
You can compress older historical Intraday data records into higher time frames. Here are the instructions: https://www.sierrachart.com/index.php?page=doc/doc_JoinIntradayData.php#IncreasingStorageTimeUnit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-18 21:11:11] |
Thanks, this is exactly what I was looking for. I would like to request an enhancement though - would it be possible to make the process more automatic so users can reduce the size of old data on a scheduled basis - like the current support for large file sizes?
[2014-08-18 22:24:47] |
This eventually will come and will be replacing the current large Intraday data file splitting feature.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-19 03:06:33
