Date/Time: Sun, 19 May 2024 04:56:37 +0000
Transfering spreadsheet - Non CLR
View Count: 911
[2014-08-18 20:22:17] |
User53601 - Posts: 105 |
I share spreadsheet study which I have created in Non CLR version of Spreadsheet. It works ok in my Sierra. Friend installed the files in his PC according to SC instructions. He added the spreadsheet study as a collection do the chart, so far it is ok. The problem is that the formulas do not calculate the values. The formulas were transfered to the second Sierra , however the values are not calculated. Can you advise how to proceed with solution.. Thank you |
Spreadsheet.png / V - Attached On 2014-08-18 20:22:03 UTC - Size: 64.63 KB - 329 views |
[2014-08-18 23:49:30] |
You need to provide us the spreadsheet file. Attach it by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-19 19:48:27] |
I will try other way: May it be the case, that formulas in cells O1 and P1 in the FORMULA SOURCE SHEET are not transferred to other Sierra? |
[2014-08-19 21:23:48] |
The formulas are contained within the spreadsheet file. They will definitely transfer.
