Date/Time: Sun, 19 May 2024 10:21:12 +0000
Chart stuck in "replay" mode
View Count: 1068
[2014-08-18 15:17:01] |
User68474 - Posts: 195 |
Chart says "Replay"...how to get out of replay mode? Don't want to just lose my chart because I have a lot of references marked on it.
[2014-08-18 16:09:26] |
Go to the chart and select Chart >> Replay Chart. Press the Stop button. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-18 17:35:08] |
The Region Data Line still contains "Replay/BkTest Fills". Why? how to get out of that mode??
[2014-08-18 17:37:59] |
Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_TradeMenu.html#SimulationFillsSource Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
