Date/Time: Sun, 28 Apr 2024 22:06:26 +0000
Keeping settings but switching from vista to windows 7
View Count: 2305
[2013-03-23 14:44:30] |
User21243 - Posts: 43 |
If i am going to switch my operating system from windows vista 64 bit to windows 7 32 bit will my current Sierra charts stuff still be the same? All my settings and layouts. I am just going to copy my entire Sierra charts app, folders etc and then load them onto the new windows 7? Will that work? Or will this mess up all of my settings and layouts? Thanks |
[2013-03-23 16:09:53] |
FGBL07 - Posts: 19 |
How are you going to switch? By performing an upgrade? I did that myself some time ago but I upgraded form Vista 64-Bit to W7 64-Bit. No problems with Sierrachart. Just be sure to make a complete backup before this operation. I highly recommend this upgrade. |
[2013-03-23 16:33:57] |
thanks for the reply Yeah just upgrading, I am done with Vista and am not sure on Windows 8. |
[2013-03-23 19:24:19] |
Sierra Chart - Max - Posts: 5597 |
As long as Sierra Chart will be in the same folder there should be no problems. For more information on moving Sierra Chart please see: http://www.sierrachart.com/index.php?l=doc/helpdetails15.html Sierra Chart Support Date Time Of Last Edit: 2013-03-23 19:24:50
[2013-03-24 04:20:30] |
Nothing special to do. Just upgrade and everything will be the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
