Date/Time: Sun, 19 May 2024 04:11:24 +0000
change data feed
View Count: 1020
[2014-08-18 13:09:31] |
User23186 - Posts: 1 |
I just started using Sierra Charts and used your free data feed initially. I have now purchased data from IQ and their symbols are different. How do I change the chart symbols so that i can get their feed. At the moment The Sierra symbols are not recognised by IQ feed The Sierra symbols that I have been using are GER30 & EustX50 I need to use XG# & ES# for IG |
[2014-08-18 16:39:45] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html#ChangingChartSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
