Date/Time: Sun, 19 May 2024 12:15:29 +0000
The problem with downloading the tool list.
View Count: 893
[2014-08-18 04:14:24] |
2garin - Posts: 184 |
Good afternoon. Help solve the problem associated with downloading a list of characters. Command "Update From Server" in the "Global Symbol Settings" list does not load. Log terminal attached. Thank you. Date Time Of Last Edit: 2014-08-18 04:19:09
Private File |
[2014-08-18 06:15:16] |
When you logged into Sierra Chart did you use the proxy server settings? Do you know if you are on a network which requires a proxy server for HTTP requests? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
