Date/Time: Sun, 19 May 2024 08:48:11 +0000
Intraday chart OK but Daily Chart for RUS FUTURES TFU4 IS WAY WAY OFF - BASICALLY BLANK
View Count: 1544
[2014-08-17 15:36:01] |
User75277 - Posts: 33 |
Howdy, I have attached some things which will help you see the condition. Thanks for your help. God Bless. |
2014 08 17 RUS TFU4 DAILY CHART NO DATA EXCEPT LINE AT TOP A.png / V - Attached On 2014-08-17 15:35:00 UTC - Size: 20.29 KB - 393 views 2014 08 17 RUS TFU4 DAILY CHART NO DATA EXCEPT LINE AT TOP A.png / V - Attached On 2014-08-17 15:35:22 UTC - Size: 56.39 KB - 352 views 2014 08 17 RUS TFU4 DATA WINDOW TFU4.dly.txt - Attached On 2014-08-17 15:35:41 UTC - Size: 16.2 KB - 352 views |
[2014-08-17 19:48:26] |
TFU4 is not a valid futures contract symbol for the service you are using. Open a new chart through File >> Find Symbol and locate the proper symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-18 10:38:58] |
Howdy, I do not understand your reply. TFU4 on my minute and tick charts gets the current data from TransAct. Also, in my TransAct Trade Platform TFU4 IS the symbol used. The broker says TFU4 is the symbol. So, What where am I going wrong? Thanks. |
[2014-08-18 12:44:10] |
apollofl - Posts: 95 |
The Symbol for the Russell Historical chart is RJ#
[2014-08-18 12:51:20] |
User021827 - Posts: 174 |
historical daily symbol may be different from intraday , tick, minute chart
[2014-08-18 13:11:04] |
Thanks.
[2014-08-18 16:10:58] |
Let us know if you still need help.
[2014-08-18 17:18:50] |
Thanks. RJ# works. Suprised broker did not know about this. God bless.
[2014-08-18 17:26:50] |
We do not recommend using that symbol it is not clear what contract month it is near the expiration of the contract. We recommend opening a Historical Daily chart through File >> Find Symbol and the appropriate symbol will be selected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-18 17:27:22
[2014-08-18 17:47:40] |
Oh, great. Thanks. I was wondering about that. God Bless.
