Date/Time: Sun, 19 May 2024 10:20:44 +0000
sierra licence for more then 2 pc
View Count: 964
[2014-08-17 15:12:07] |
User30743 - Posts: 364 |
hi, i have a sierra package 5 for 2 laptops, works fine, but now, id like to add one more pc to it, to have it run for three laptops. is it possible somehow? |
[2014-08-18 02:17:58] |
Since you are on package 5 you can use Sierra Chart on three systems at a time.
[2014-08-18 08:49:33] |
well, cool, good news, but.. how is it possible that when i try to connect the third laptop, the first two starts disconnecting from datafeed?
[2014-08-18 09:12:10] |
This is an issue with the particular Data or Trading service you are using. So you need to contact the Service about that. It is not a Sierra Chart limitation.
