Date/Time: Sun, 19 May 2024 04:37:06 +0000
sc.MovingAverage()
View Count: 993
[2014-08-16 10:36:09] |
crazybears - Posts: 314 |
Hi SC Support Could you check this function because when set MOVAVGTYPE_EXPONENTIAL it doesn't return a value like mov exp , with others settings all works fine , i mean MOVAVGTYPE_SIMPLE , smoothed ecc. thanks |
[2014-08-16 10:52:00] |
seems wilders mov avg returns same value as smoothed mov avg
[2014-08-16 12:29:34] |
Could you check this function because when set MOVAVGTYPE_EXPONENTIAL it doesn't return a value like mov exp , with others settings all works fine , i mean MOVAVGTYPE_SIMPLE , smoothed ecc. seems wilders mov avg returns same value as smoothed mov avg It is possible they could be similar.
