Date/Time: Sun, 19 May 2024 08:28:50 +0000
Drawing 'one-off' object
View Count: 1070
[2014-08-15 23:12:17] |
User34124 - Posts: 271 |
Is there a setting which would allow a user to draw an object, then after it's creation, automatically revert back to 'pointer' or 'hand-grip'? At the moment the quickest solution I have found is right-click, then click pointer, or shortcut Alt-h. However, if one wants to draw a rectangle or line every few minutes then this gets tedious. |
[2014-08-17 11:27:46] |
Yes. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#SettingtheDefaultTool Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-17 18:52:02] |
Perfect. Thanks. Is there a way to 'delete last object' from all charts, via any chart which has the object on? Example if 'copy drawings from chart#s' is selected via Advanced Chart Settings, to then delete the object one must go to the chart it was created on. Is there not a similar way for an drawing to get deleted on a different chart and the source chart then become the slave and replicate the deletion? Please let me know if I should make a new thread for this. |
[2014-08-17 19:52:25] |
This is not supported or planned.
[2014-08-17 20:29:11] |
Ok is there a way to utilise third party programming/programmer to add this option in? As in TS and easylanguage, JForex and Java etc
[2014-08-18 09:10:22] |
Yes, it may be possible. However, it is not very simple. We would not recommend going through the extensive work to find someone and have them do something advanced like this. So in general, we would say this is not possible. So please do not try. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-18 22:48:18
[2014-08-18 22:42:26] |
Alright thanks
