Date/Time: Sat, 18 May 2024 22:26:53 +0000
Is there a way to get the instance of daily high & low for each bar in a time-based chart?
View Count: 875
[2014-08-15 15:27:51] |
vrunrun - Posts: 53 |
Hi SC, As the daily high/low are subjected to fluctuate during the day, is there any study/spreadsheet function which allow me to capture the snapshot of daily high and low with each bar in a time-based chart? I tried studies "Daily OHLC" and "High/Low for time period" but they can only captured the final high/low by the end of time period specified. Pls advise. Thx. |
[2014-08-15 16:42:16] |
You will need to use the Daily OHLC study and set these inputs as follows: Reference Days Back = 0 Graph High and Low Historically = Yes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
