Date/Time: Thu, 10 Sep 2026 08:02:45 +0000
Bracket Order Question
View Count: 1227
| [2014-08-14 22:53:41] |
From user: I want a multi-bracket order with the contracts for targets and stops showing in the column. 3 contract buy, two with a 4 tick profit and one with a 8 tick profit and breakeven stop on the third. I want all of the orders and number of contracts on the dome so I can move them if need be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-08-14 23:34:25] |
We have prepared a Trade Window configuration file which is attached to this post. For instructions to use it, follow the instructions here: Basic Trading and the Trade Window: Using a Trade Window Configuration File Provided to You Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-14 23:34:55
