Date/Time: Sat, 18 May 2024 19:50:53 +0000
[User Discussion] - Log
View Count: 887
[2014-08-14 21:36:56] |
conr - Posts: 204 |
Is there a way to turn off the log window? Pop ups are a pain. If not can you put one in? Thanks. |
[2014-08-14 22:41:04] |
No, definitely not. If the Message Log is opening there is a reason for it because there is a particular message you should be aware of.
[2014-08-15 00:03:05] |
conr - Posts: 204 |
I understand that but shouldn't that be left to up to the user? Problem is that every Sunday when I start up my system for the week I get a ton of log windows. Also, and more frustrating, everyday after the market close I get numerous log repeating the same thing stating: "TransAct Trading | Disconnected from the server. | 2014-08-14 16:33:36" This happens every single day when the Globex shuts down for maint. |
[2014-08-15 00:13:31] |
Sounds like you are referring to the Trade Service Log. That will open up during connections to TransAct and I think also disconnections . This is something which TransAct has control over. They have the ability to pop open that window through the DTC protocol.
[2014-08-15 01:38:12] |
User120827 - Posts: 77 |
Could we at least be able to move the log window away from the middle of the screen ? Both trade service log window and message log window. I just want to resize it and move it off to the side. I dont care if it cant be disabled. thats all thanks |
[2014-08-15 02:25:21] |
Yes of course. You should have no trouble moving the Log windows wherever you need.
[2014-08-15 03:30:28] |
No ,I meant the default location where it pops up. Not moving it once it pops up. thanks |
[2014-08-15 03:36:19] |
Sawtooth - Posts: 4000 |
Here's what I do: Grab the corner of the Log and shrink it to a small size, then part it out of the way. When I want to see what is in the log, I grab the corner again and expand it. Result: no pop-ups. |
[2014-08-15 03:53:52] |
Cool So you just leave it open, ok. I am a little slow I guess ! lol Thanks Tom |
