Date/Time: Sat, 18 May 2024 17:29:48 +0000
Shortcut menu, customize
View Count: 958
[2014-08-14 16:30:15] |
User57562 - Posts: 98 |
"Available menu items" seems mostly random. How about alphabetic??? Or even a search/find tool? I just noticed that selected order need not be the actual. See image. Date Time Of Last Edit: 2014-08-14 16:47:29
Selected&ActualMenuItems.png / V - Attached On 2014-08-14 16:46:13 UTC - Size: 59.39 KB - 299 views |
[2014-08-14 17:51:00] |
The order of the menu items you see in the Available Menu Items list in Global Settings >>Customize Chart Shortcut Menu, is based upon the order of the menu items that you see on the main menu.
[2014-08-14 18:00:37] |
And where is that? Please offer alpha as a sort. Else, I can't find goodies I have read about. |
[2014-08-14 20:20:14] |
Where is what? If you are referring to the main menu, this is the menu you see below the title bar of the main Sierra Chart window.
